beachbum
- Niagara Falls, Ontario, Canada
- SX
I use a Trailer Valet... would work for u perfectly.
Nice! Yes definitely talking about 19ft's...my only concern is that my driveway is slanted, not too badly but it is. However; it seems like that would make it easier to back into the garag because my garages has very tall ceilings and the angle would make sense. I see you have yours parked front first, did you do that with a dolly or...?View attachment 54525
Yes...if your asking about the 19fts
After getting the tires deflated a bit and on wheel dollys I wrapped a tow strap around the trailer and pretty much did a " tug of war" thing for an hour until it was where I wanted it. Tricky part was moving it around the garage ceiling support pole which is towards the stern on the port side in the pic...Nice! Yes definitely talking about 19ft's...my only concern is that my driveway is slanted, not too badly but it is. However; it seems like that would make it easier to back into the garag because my garages has very tall ceilings and the angle would make sense. I see you have yours parked front first, did you do that with a dolly or...?
It will fit but you will need to remove the stop washers for the tower. You can get some 1" threaded 1/4-20 hex spacers, bolts, washers and nuts and make an extension to the cable so it will allow you to lower it and adjust so it stops just above the steering wheel. This will give you plenty of room. Mine fits in an 83" opening after doing the tower mod and I do not deflate my tires or anything other than have the jack in the lowest position it can still roll. Here's how you remove the washers...Alright! Need votes please..will a 2017 AR190 fit? "YES" or "No"? Here's a pic of my garage. As you can see, my driveway is slanted and my garage opening is arched. At the lowest height, I am measuring 7'3. I'd like to put the boat where the 'stang is currently parked or in my third stall which you can't see here but is on the opposite side of the garage. Same measurements...Oh! And I'm driving 2.5 hours to pick up the boat, there is no return policy if it doesn't fit so I'll be SOL if it can't go in. Thoughts? No pressure!! LOL!!
