- Lake Ray Roberts, Texas
- Boatless
- NA
- Other
- NA
Just disconnect the wire I would think would save you cutting it.
If you are using an On/Off switch (option1), then you would put the switch between the loop sense wire.ok went back and read the above post. Im not sure I understand using one end of the sensing loop. How does the switch get connected then? The switch doesn't go between the two ends so it is either on or off?
Good luck with the install. Make sure you update us with pictures.The bottom one. Figure since I had it might as well use it. It is only an on and off as I only had one battery when the boat was new
