? Redundant Port Engine Issue-Limited RPM
@props2you we are definitely having the same symptoms. Mine is still at the dealer.
Quick update after the weekend! I did change out the starting battery with a new GRP24 Duracell. Once installed I turned everything back on and immediately had the port engine alarm, everything looked and seemed normal. I started both engines and the alarm immediately disappeared. Assuming the alarm was still triggered from previous battery/memory. Was out all weekend and not a single alarm or issue. Did not need to use emergency parallel and ran the boat in normal operation without issue. Although, I still need to build my trust back that there isn't an alarm each time I start.
Who knew the bad starting battery would wreak so much havoc!?!?
