replacement scupper valve
rick johnston
Marblehead, Ohio
getting ready to replace the factory original and want a good stainless replacement. Have a name, Attwood Scupper Valve and dimensions but where do you buy?
2004 SX230
any suggestions?
thank you all
Rick J.
I bought this one:
https://www.replacementboatparts.com/stainlesssteellongscupper112hose.aspx
I used 3M 5200 to seal it in. Had trouble getting the scupper hose back on and had to expand it a little with a muffler expander tool, then it slipped right on.
When using sealant, it a job for 2 people. Someone to hold the scupper in place from the back of the boat, and then someone to tighten it from the inside with a large set of pliers.
-Greg
You might want consider using 3M 4200 or life calk. If you ever needed to remove a fitting with 5200 you'll need dynamite.
I had a 05 SX230 and used the Attwood scupper. Wood definitely use 5200 to seal. Should never have to take this out again.
Papa
