Repower 2004 AR210 with MR-1 HO's
Have you had a chance to check out what happened to that engine?
not yet its... all ready to yank out and put on the bench... i think it just broke a gear or jack shaft in the gear reduction..
@84rzv500r Do know what the thread sizes are on this fitting? Or better yet where you purchased it with a part number. I installed a SBT rebuilt MR1 in our boat and I’m having an issue with an oil pressure alarm when I throttle down. SBT says I need to verify what the actual pressure is by installing a gauge.
all fittings are standard 1/8" NPT in the oil system
ok Just solved the MR-1 oil drain challenge... for less than $30 a side !!
3068-08-125 | Metric Banjo Bolt M8X1.25 $3.80 each
3069HB-04-08 | 1/4" Hose Barb x M8 Metric Banjo (Low PSI) $6.35 each
Stainless Steel Bulkhead 1/4” Hose ID Barb Fitting Fuel Water Boat Air Splicer $16 each
dexierp Protection Force Round Cap for 1/4" 6.5mm OD (Pack of 50) Pipe Post Tube End Cover 1/4-20 UNC 1/4-28 UNF Screw Thread Protectors Elastic Rubber $10
I have a big roll of 1/4" USCG approved 1/4 fuel line
and i already ditched the grease fitting in the thermostat housing so ill pop the bulkhead connector in that hole....
I'll just use my Milwaukee M18 transfer pump necked down to 1/4" to suck the sump dry at oil change....
easy peasy
84rzv500r,​
How is this oil mod working for your MR1's? I'm about to try it myself. Thanks, Russell
works great
