SBT Engines Install - 212X 2010
Dan2poole
Hi All,
We have recently had a few issues with the stock 212x engines on our 2010 jet boat.
As we are located in the Middle East (Oman), it was significantly difficult to obtain the correct parts/ repair, therefore decided to purchase 2 x brand new SBT engines from the USA and ship to Oman for install by the Yamaha dealer. All other supporting parts such as the shaft coupler, gaskets, clips and seals are OEM.
I will post progress updates on this thread on how the engines run and any issues we experience (if any!).
Should be on the water ready for testing in the next 7 days.
Any advice on the break-in of the engines would be much appreciated.
Thanks
Beachbummer
Houston TX
Be sure to have a good idea of the cause of the failure to prevent it from affecting your replacement engine. Best of Luck!
84rzv500r
Lower Keys MM29
Did kinda the same thing...lotsa pics... in the build link in my signature.... I didn't have any like engines to start with...
HawaiiBreeze
Oahu Hawaii
Aloha,
I would think that SBT should provide that information. Best to contact them and be sure to follow their exact procedures in case there is an issue and they point at your break-in procedure as a contributory factor.
Good Luck!
84rzv500r
Lower Keys MM29
they do its in the packet that comes with the engine... it is essentially the Yamaha factory breakin procedure...
Dan2poole
Hey,
Quick update on progress. So we managed to have the yamaha engineer come out for for the sea trials. Engines are working well during the break-in..
Problem is that we have cavitation problems. We have had this before and installed new plugs but this didnt help too much so we just learned to gradually increase the rpm to get it on plane but the cavitation was always there and never went away.
During the installation, yamaha installed some new performance sbt implellers, so I am thinking they may not have used gasket sealent when reinstalling the housing.
Anyways, I have been at the boat most of today stripping out the old sealent around the pump/ intake plates. The sealent was very degraded, photos attached.
I applied new silcone and then once dry, added a layer of liquid rubber. Photos attached.
Feedback welcomed.
Thanks
84rzv500r
Lower Keys MM29
what about the inside gaps on the pump tunnel ? they should be sealed smooth with silicone and I usually use a little (very light coat) Permatex aviation form-a-gasket on the pump to transom plate and stator to pump junctions... clean and marine antisieze on all threads..
Dan2poole
Hey, thanks for the reply,
I managed to get through the grates to apply silicone and liquid rubber (Flex Seal) to the gaps within the pump tunnel.
Heading out to test tomorrow, will post results.
Thanks
84rzv500r
Lower Keys MM29
:winkingthumbsup" i have 70 hours on my MR-1 HO SBT engines no issues.. 20psi idle oil pressure cold 10 psi hot and 60psi at 8000 rpm hot... If I do another set I will send the engines out to have the heads ported by ATR... there is free horsepower in these heads...
Top Bottom
