SOLD SBT impeller housings & wear rings $250 pr.
WildCatFan54
Lexington , Ky.
I purchased these about a year ago to have as spares for my 16 AR240. Now that I have sold that boat and the newer model years have redesigned pumps , I will never need them. Currently listed on SBT website at $209 each. These are the housings with Delrin wear rings. The OE are steel and can't be relined. With them you must replace housing to get lining. Much more expensive than simply buying new Delrin lining to install in this housing. Some reports indicate that these are also much quieter than the OE stainless steel ? I have already inserted new collars (transom plate side) of these and will also include new dowel pins for the other side.
New OE Replacement Yamaha Jet Pump Housing with replaceable Delrin Liner.
  • Fits 66V-51312-00-94
  • 66V-51312-01-94
  • 66V-51312-01-00
Just to confirm these work with our stock impellers and you don't have to mate with SBT or some other aftermarket impellers?
Correct.
That is my understanding but @swatski is the expert. I believe them to be compatible with basically all Yamaha from about 2008 until 2018 ? I provided the OE equivalent part numbers in original post.
I get very good service out of mine and no dissimilar metal corrosion so no ringing of the pump and impeller when running on the trailer so you are not wearing down the impeller edges when the liners start to swell.
Yamaha is using the plastic liners stock starting with the 2019 pumps Sea doo has used them for eons.
Sent you a PM...
I'll take them if still available. PM sent.
