Blake
- Scarab
- HO Impulse
I have sent this message to Scarab itself and rotax and cant get any response from either of them on how to get our brand new boat working correctly.
When we first received the boat we had problems with it cavitating and making the engine overheat and then shut down. Took it to a scarab dealer in the Chicago IL area for repairs. They applied a sealant around the ride plate. This was at the end of the 2014 boating season so we could not confirm that year that it was fixed.
This summer it was still cavitating but not overheating when applying full throttle and would not even run in ski mode 5. I Noticed that the reverse basket was not fully locking up when going in forward gear. I adjusted the linkage to make it lock in the up position and that helped out a lot we were now able to use ski mode 5 but still were having cavitation problems. Took it to a scarab dealer in Missouri to get looked at again they said they could not find what was causing the problem so they just reprogrammed the engine.
Now the last time and only the third time we were able to use the boat cause of it being worked on all the time I have noticed that it still cavitates. At 8000 rpm when the boat first starts going under full throttle it starts to cavitate and loses load on the engine and makes the engine to bounce up to 9000 rpm for about one or two seconds then comes back down to 8000 rpm and then stops cavitating about one second after the rpms come down to 8000.
That is the main problem that we have been with this boat besides a couple more that I have not been satisfied with. When in ski mode 5 while pulling a wake boarder and 3 people in the boat it has been able to pull them out of the water now and not like before when it was cavitating bad but I have noticed when the speed is set to 21 mph the boat would only get up to 15 to 17 mph after about 10 - 15 mins of pulling the boarder and would never get to the set 21 mph. The Scarab sales rep that I talked to a couple of days ago said that the ski mode is only for beginners and he never uses it for what he does but I don't think that should be right because when you are wake boarding you want a set speed to cruise at to give you the best wake that the boat can produce and if ski mode cant do this this the boat is pointless for wake boarding even though it was advertised to us this feature as a waterboarding type of boat. Another problem I've notice is about five times I have heard a loud rattle around 2000 rpm and idle and would not let me increase engine speed above 2000 rpm then I heard a loud bang and finally let me have full engine speed.
