Serial number on 2021 255XD - each engine?
CaptainVinnie
255XD
I’m looking to purchase a 2021 Yamaha 255 Xd, the bank I’m financing with is asking for the serial number, does the boat haul have a separate serial number then the engine? And does each engine have its own serial number? Or is the haul and engines only have one? Thanks
The boat has a number, probably starting with YAM. And then each engine has a serial number as well. You should be able to get all three numbers from the seller.
In Michigan on the boat registration, it lists a "Hull ID" that starts with YAM. No mention is made of the two engine serial numbers.
did you ever find this? Im purchasing a 2021 255XD and my bank is asking for the engine serial numbers as well. The seller can’t find it and boat is 2.5 hours away so I can’t see it in person that easily.
Those numbers are only needed when a boat is sold without a motor and needs one to be added to make the boat complete.
You do not give the bank the engine numbers on a car/ truck and you do not give them on a jet ski. Tell the bank it is a in board motor boat and that they are idiots.​
My insurance company asked for my engine numbers. I bought used at a dealer but they were on the invoice or whatever doc it is.
@n33d45p33d maybe the guy you’re buying from has that paperwork and just hasn’t checked?
