Neutron
- New Bern, NC
Here is a few more pics of the transom mount.@Neutron any other pictures of mount and how are the displays as far as reading bottom items?
Because of the angle forward i had to shim the right side bolt with a short stack of stainless washers. I also used large thick stainless washers on both sides of the hull to improve strength and spread it over a greater area. I used 1/4 20 bolts and nuts. Easily reached after removing the cover that surrounds the 2 clean out ports.
