Welcome to Jetboaters.net!
Figured we would see whats everyone is planning. I usually do wings of course but i will also do some crab cakes this year as well as a few other things.
The top layer is meatballs which are 50% ground beef and 50% pork sausage which Emma requested to make sliders with marinara and mozerella and the smoked sausage that Gavin requested. The lower level is chicken wings. They cooked around 225 degrees for three hours using indirect heat and with chunks of hickory in the coal. I flipped the meatballs and chicken about 2 hours in. It all turned out great.
They were awesome! Didn't last long either. The one mistake I made is I lined the bottom of the serving pan with papertowels to soak up some of the grease from the bacon. The tots stuck to the paper towel so you had to peel the bottom layer of tots off the paper towel, sometimes getting a little paper towel with your bite. That didn't stop everyone from still polishing them off if that tells you anything!!
We made tailgate sandwiches which are made with Kings Hawaiian rolls, black forest ham, and povalone cheese. You cut the rolls in half and place the bottoms in a greased baking pan. Build the sandwiches with ham on bottom and then cheese and put the top back on. Then take a stick of melted butter, tablespoon of mustard, tablespoon of woshtishor (sp), and 2 tablespoons of minced onions all mixed together. Pour that mixture over the top. Then sprinkle shredded parmisian cheese and bake for 30 mins at 350. Slice and serve.
We also made guacamole following @txav8r 's recipe, homemade salsa, and some spinach artichoke dip. Needless to say we ate good.
