FLJetBoater
- 242 Limited S E-Series
So I’m trying to get in and diagnose the solenoid. Can someone please tell me if what I’m doing is necessary? It seems like an excruciating amount of work.
First, electrical boxes are bolted from the clean out hatch through. You have to hold the bolt to take the nut off so you either need 2 people or the ability to balance a wrench on it perfectly and not have it fly off when it’s spinning around while you’re undoing the nut.
Then once you have those 4 bolts out the solenoid is bolted from the back of the electrical box. Again, why from the back?? If they had just put the 4 bolts for the solenoid in the front, all this could be done without removing the box at all. Am I missing something?
