HangOutdoors
- Royal Oak, MI
There was another thread on here that discussed water getting in through the clean out hatch. My last outing I did have some get in. This morning I have some Marking dye, not stainable and I put water in different areas of the swim platform, cup holders, clean out tube and top of the cover under the clean out hatch. What I have confirmed, as was indicated in the other thread which I can't find, that water does in fact seep through. This is the large cover that has the two clean out plugs in it. I was going to pull it up and put in a gasket, but once I realized it is pretty set in there with the clean out tubes and that I may cause another issue. I decided to use a Marine Grade silicone sealant around the whole thing. I used clear. I sure didn't want to use 5200, so I decided to try the Marine silicone. It is above the water line of course and it only gets water randomly based on either a wave or people getting out of the water. I can verify with the dye now that it is sealed and all the water under the hatch goes into the tubes or into the 1 inch drain as intended. Picture to follow.
