dan144k
- Palatine, IL
I had some else drive the boat and walked arounf trying to isolate and identify potential noise points.
1. Well I could sense a lot of harmonics from my swim deck area.
2. When on plane boat would get louder as exhaust discharge would come out of the water.
3. Thicker engine hatch bubble gasket (done in the past 5/8") now 3/4"
4. Fuel hatch
5. Hollow corner areas of boat rear
6. Engine compartment area holes/ seams
I had all my exhaust system removed during the summer to install a ballast pumps (another post) and did all these items at once. It would have been nice to to do each step and record results indivually, but I was unable to. And I did not use any electronic sound recording instruments either. Good old ear and conversation testing.
1a. I installed KnoKnoise (thin membrane material with self adheasive) on all flat and curved surfaces, focusing on fiberglass at swim deck area. Where it transitions from large exhaust area and goes to narrow swim platform area. Amazon $60 KnuKonceptz Kno Knoise Kolossus Sound Deadener 100Mil Thick 14sq ft Door Kit, product similar to dynamat.
1b. 2nd sound product applied was 1" Sounddown (1/2" thick foam-1/8" membrane-1/2" thick foam, self adheasive on side and foam face on other side) I installed the sounddown on top of the knoknoise al over the exhaust compartment. Soundown kit from Jetboatpilot.com
2. Exhaust water box. I foil taped the edge of the Sounddown and wrapped around the waterbox, I did not use the adheasive, left the backing on the sounddown. Measured, cut, and positioned it. Held in place using large zip tie and then the rubber straps which hold the waterbox in place. Did not insulate the ends on waterbox on purpose, my theory was water could drain out this way.
3. Removed 5/8" bulb gasket and installed 3/4" from mcmaster carr item# 93085K82 Weather-Resistant EPDM Foam Rubber Bulb Seal Adhesive Back, 3/4" Overall Width, 3/4" Overall HT. , 50 ft. Length.
Used the extra around the fuel hatch cover.
4. Fuel hatch installed the KnoKnoise membrane and 3" sound absorbing foam from Mcmaster Carr
9710T66 Sound Absorber Sheet, Plain-Back Egg Crate, 3" Thickness, 54" X 54". Use the extra in the engine compartment to absorb random noise. Rolled it up about 12" round with 4 large zip ties and just lay on top of the engines. Also have in engine are 2 large foam wedges.
5. Rear area of boat outer corners are hollow. Unable to push entire foam sound wedge bass trap into corner so I cut up the 24" wedges into 6" length and shoved them into the corners behind the exhaust systems.
Wedges from Amazon $80 4 Corner Bass Trap - 12" x 12" x 24" Acoustic Sound Foam Kit - SoundProofing and Deadening
6. Found some white low expansion foam for windows and went around the engine compartment. Found many large seam with 1" gap.
7. Also found a harmonic vibrabrating panel on front of the boat, seat side of anchor locker. Large panel at front of boat was humming from vibration. Installed the KnoKnoise on inside of anchor locker.
From discussing with my wife and friends if it made a difference. Everybody says YES it does. Boat can run down the river at 30 mph and you can have a conversation and hear the radio easily. Prior you had to yell at each other basically. So money well spent for use.
But of note taking the rubber hoses off exhaust sytem was an awful difficult to do. Just a very tight area with minimal leverage.
4. Fuel hatch
