Hike
- Montross, VA
- SX
I thought I'd share what happened on my first ride of the season last weekend after changing plugs.
I had swapped out the spark plugs in my 2008 sx230 using a 5/8 spark plug socket, the kind with the rubber grommet inside to hold the plugs. When putting the ignition plugs back on, I noticed I didn't have a perfect flush over one of the cylinders (port) but didn't think too much of it since the it was fine after bolting it down. Engines started up, no problem.
Go to launch, starts up fine again. After 45 seconds of WOT (wide open throttle), the port engine shuts off, no warning lights, no sounds of misfiring. Tried again, same thing happened, limped back home. Checked my socket to find the rubber grommet was missing! Sure enough it was the cylinder that was slightly off. It took me 20 min with a needle nose and the 5/8 socket to try and get that sucker out of there, but it finally came out.
![IMG_1310.jpeg IMG_1310.jpeg](https://jetboaters.nyc3.digitaloceanspaces.com/data/attachments/114/114216-e06817b2795e710a9eb52e143812b3cf.jpg?hash=4GgXsnlecQ)
Went out again with the confidence that all is fixed and the same thing happened again.. port engine dies 45 sec after WOT. Turned off both engines, scratched my head and tried again. Maybe the ECU had to clear? It was fine after that for the rest of the weekend. We had a great time after that!
Note: I had upgraded to Iridium plugs (CR9EIX) and swapped out my air filters with Riva Racing K&N Filters, I gained about 200 RPMs on the tach to about 10,200!
