sr230 yamaha throttle shifter
z3cta
Peoria AZ, Lake Pleasant
SR
Good morning
Help please
Can anyone tell me if the throttle shifter should stay up on its own or constantly needs to be held up to the desired speed? Mine will not stay up and I want to know if that is normal. I own a 2003 yamaha sr230
Scottintexas
Corinth, TX (DFW)
glad to have you on board,
update your profile with your location so we know where you're boating,
How long have you owned your boat? does it have the mr1 engines or 2 stroke?
throttles slipping back is a common problem, we have it documented along with many other issues in our FAQ tab at the top of the page,
here is the link to fixing it,
Beachbummer
Houston TX
I believe your throttles on the SR are the less common teleflex style levers. If you post a picture that will help us know for certain. I believe there are friction screws on the assembly either on the sides or under. Perhaps the parts diagram can help locate them.
Beachbummer
Houston TX
z3cta
SR
Glad to be here, thanks for the feedback. I have the MR1 engines, had it for about 3 years now
btw, I am in Greater Phoenix, Lake Pleasant
z3cta
SR
Beachbummer
Houston TX
Yes, that ultra flex lettering is the same on the SeaDoos. I think the screws are underneath, so it needs to come out to be tightened.
z3cta
SR
Hey, thank man, I hope that works. Seems an easy fix. Greatly appreciate it . I will post updates
