euro_e30
- Hampstead, NC
Was out on the boat today (after putting two new ecu in due to injector / fueling issues) she ran great last week but today when we went out and was cruising at 7.5k for about 2-3 min with a small chop the port motor just cut off , I then started it back up and ran good for a little then cut off again, started it once again and it cut off after a even shorter period. This time I was not able to start it and had to limp home on one
Once I got home I tried to start on land no luck I pulled the plugs to inspect and they looked dry , did the injector test through yds all checked out and ran the fuel pump test all good . Then she started right up on land
Two things I’m thinking I don’t think it’s the clean out hatch sensors as every time it stalled it would crank ( correct me if I’m understanding this incorrectly )
Secondly is it a fuel pump issue? Weird that it checks out in yds and runs on land fine
Thinking of trying it again in the water tomorrow but would love any input
