+1 on the Stoltz roller. Stoltz is more rubber like as opposed to the stock plastic. The pressure on the roller shown in your picture looks the same as mine I think its typical.Are the Stoltz made of a softer material?
3.5 or 4” is best for your trailer. Some people have slightly bent the holders apart to get the 4” to fit. I went with the 3.5.the 4" stoltz doesnt seem available on amazon anymore. Will the 3" work on a 2018 240?
https://www.amazon.com/STOLTZ-IND-ULT-3-Boating-Equipment/dp/B0000AYACG/ref=sr_1_1?crid=3JPDA8OW5RY59&keywords=stoltz+bow+roller&qid=1553385060&s=gateway&sprefix=stoltz,aps,161&sr=8-1
Where did you pick the roller up @AJack ?I just installed the 3.5" today, it's slightly narrower than stock, but the bracket arms easily moved in to compensate.
No, it fits with just a small gap on each side.Thanks @Stevenpigsooie Did you have to bend the holders with the 3.5"?
I just ordered from this website. $32.99 seems to be the best price available for the 3.5 inch Stoltz. Hope the website is reliable. How long was shipping for you?
Is that the stock thru hull anchor locker drain for the 2019's or an aftermarket/retrofit? I like the hooded design as my 2016 is just a thru hole.Also did the anchor locker drain valve while I was in that area.
