I wouldn't yank it off. Be careful how you hit it. I plan to get bigger end bells for the end but still haven't.Oh man. I hate to see that. Sorry about your boat and I really appreciate you sharing your pain! I’m yanking it off.
Not hard at all, just got hung up on the bunks a little strange.@chriswork There are a multitude of members who use the 4" Stoltz without issue, I am one of them. Not a scratch or a dent, it works perfectly. Not sure what happened to his boat or even how hard you have to come in and hit that to get it to do that.
Too steep for the newer hulls.Anyone try this?View attachment 128468
@HangOutdoors Your feedback has been great. We pick our new 212s next Saturday. I want to get the Stoltz roller and 60” guides before we pick-up. I know you prefer the 4” roller and that’s what I will get. Do you have the 60” PVC guides from Overton’s? I am concerned the PVC might be a bit flimsy, so I was considering the ones from Bass Pro that are steel with non-marring PVC covers. What do you think? Do you keep it covered? If so, do the guides make covering it more challenging? Thank you for your advice!I never go all the way to the roller, I am usually a few inches to a foot before the boat stops. We can't power load here, and I would be afraid of sucking something up that someone left or lost around the docks, seen some rope pieces floating one time. Our ramps aren't that steep either. I just cover the front fender with an inch or two of water on average. I go in and kill the engines once the nose of the boat is about a third of the way over the trailer moving forward. The boat stops when it goes further. I then crank it to the roller, do the 5 mph quick stop to snug, crank the slack out, hook the safety chain and off we go to finish up securing the boat..
As @tdonoughue wisely points out, it is best for each person to feel comfortable. What is right for me may not be for you. If you are not then by all means change it out or put the bigger bells on the end. It didn't cost much.
That's how we've always done it, both with our SeaDoo and Glastron. Powered loading just seems a bit risky for me. Don't like coming in hot. Do you find you sometimes are off center and up against a guide or what process do you use to get her centered with equal space between boat and guides on both sides?@JetMania I use the C.E. Smith 60" and they are great. Worked great for me.
Here is a thread on them plus a link. The L shape is metal with a pvc tube that goes over going up as well as I put covers over them. The work just fine. I also like the lights on top a lot. Makes loading in the dark and rain easy at the ramp. I keep the boat about 1.5" away from them so on both sides there is 1.5" between guides and boat. Does not affect boat being covered and my boat is always covered on the trailer. When loading at the ramp I back trailer up to water and keep it straight, then the Admiral and I switch spots and hope in the boat on back away from the ramp. She dunks the trailer till the water is just over the front trailer fender then I drive the boat slowly on the trailer, it will bump the guides and it stops about 3-4 feet from bow winch. I hope over the front, winch it on, have her pull up and hit the brake once at about 5mph and boat snugs right up. Strap it and all set to go. The guides make it effortless. The lights are great when you have poor conditions. Recommend putting your guides underneath and trimming excess, also buying Square Caps for the ends so you don't cut yourself if you walking around back there on the trailer an slip.
60" Post Guide-On With Led Lighted Posts
Share this product in the CE Smith Online Store and receive $2.00 off. These Post Guide-Ons allow you to see the location of your trailer when it's under water. Equipped with long lasting, waterproof and shockproof, one piece red and amber LED lamps.store.cesmith.com
Amazon.com: Guide-ON Post W/LED Light 60" H: Automotive
Buy Guide-ON Post W/LED Light 60" H: LED & Neon Lights - Amazon.com ✓ FREE DELIVERY possible on eligible purchaseswww.amazon.com
They are universal, shouldn’t be any difference by boat length.So most of the posts are for 24 foot boats. Do the 21s use the same roller?
