Strange reverse problem on start
Evolver7
Sugar Sand
Tango
Hello I have a sugar sand that I haven’t drove in about a month and a half in mn. Today I started her and she went fast into reverse. White smoke too. I noticed that the button on the throttle seemed to have a lot of play... I could pull it out or push it in. When I tried to engage in drive it seemed to jump a bit so I parked her and decided to wait to hear what to do... I thought maybe had something to do w the cables.... I went under the boat in a wet suit and there was no obstruction in the grate.... very strange that it was going fast into reverse on start.... any idea of what could be happening?
Evolver7
Sugar Sand
Tango
It’s a 175 hp Mercury jet sport engine 2 stroke 1998.
Cobra Jet Steering LLC
Vendor
Florida
Sounds like a cable issue there is really nothing complex about that setup , smoke has nothing to do with reverse it is a 2 stroke v6 engine , focus on the mechanical parts of the reverse bucket . It may not be going all the way into reverse and therefore not providing the full effect.
Blkrvrbart
Sugar Sand
Tango
If the stop nut on the cable housing is broken or loose, it would cause the boat to not shift correctly. Can you work on it while it’s on s trailer?
Evolver7
Sugar Sand
Tango
thank you sir!!! I started w removing this part in picture below from the right side of the reverse bucket. It looked like maybe it wasn’t even connected. A lot of loose play as well. Am I on the right track as this is part of the control cable or separate piece?
Evolver7
Sugar Sand
Tango
I also removed the throttle housing but didn’t have time this weekend to remove the cable from the throttle. I am so new to this that any progress that’s been made so far is a win
Vendor
Florida
broken cable needs to be replaced look on the reverse bucket for the end that broke off also for some reason I can not view your pictures only the small ones on the post but when I try to enlarge them it won't work
Evolver7
Sugar Sand
Tango
I can but had to run her to storage and wait until next spring to play w the throttle, cable, and whatever those pieces are that I removed In the pictures below.
