Lessee...  This would be day 3 of repair (well, not full days).  Brother got here late last weekend, so we did not wind up going out.  Good thing I hurried.
  So, today was the next day I got up to work on the boat.  Removed the Saran Wrap and everything was cured (of course--after a week).  So I went to sanding.
I only did the 320 wet sand with block.  I still had a pretty high spot of glass apparently, because it poked through almost immediately.  So I sanded everything else flush to the undamaged area, then brought the grinder back out to take down that epoxy/glass ridge just a little bit more.  Have I mentioned I hate sanding?  I hate sanding.  But it went fine.  Then it looked like this:
So, I had taken some professional advice from a real fiberglass pro friend.  He advised the Preval sprayer and to use the paste gelcoat, but thin it out with acetone.  Never did that before.  But, off I went.  So I mixed up the gelcoat with the hardener as normal (used 11 drops rather than 10, in case the thinning affected it).  Then I began carefully thinning.  I had an eyedropper and added 2ml at a time--up to 8ml for the half a jar.  I removed the little filter from the straw for the sprayer.  I carefully strained it into the container for the sprayer--only to find it barely came up to the straw when I put the top on.  Uho.
I tried it, but no dice.  Not enough to spray.  So, I took off the sprayer top and unceremoniously dumped some more acetone into the mix, covered with one of the covers, and shook it around.  Put the sprayer back onto the reservoir and I was in business.  It really did spray very nicely, but I do wish that I had had more material with which to work.  I still ran out rather quickly, but I had enough to get a good coat on the whole area.
Next, I took some PVA mold release, cleaned out the sprayer well with acetone, dried it all, and put in the PVA.  See, same pro friend clued me in that I shouldn't cover with Saran Wrap--instead use this stuff to spray over the wet gelcoat.  It will dry, leaving a coating on top which is airproof, which then will cure the gelcoat.  So, armed with this knowledge, I sprayed the PVA (full strength) onto the area.  Now I have:
(the repair area is at the very left side of the second picture, as I was looking practically into the sun and need to frame it that way or it would darken the whole pic).
Anyway, I think this is great progress.  I still have lots of divots there to fill (not sure if I will do the paste or the spray again--but now I know how to do both!).  But at least when this dries I am pretty sure the boat is runnable.  By the way, the PVA will come off with a Scotch pad, I am told.
Oh, pro tip:  remember that PVA stuff?  Don't try to clean it up with acetone.  If you pour in acetone it immediately gels.  Left a nice thin, strandy film in my sprayer when I poured it in.  Very much a mess:
This is what I fished out of the reservoir and dumped onto the nearby groundcover.  Yuck.  Almost ruined that sprayer, I am sure (but at $5, not all that bad).  Fortunately, I saved it.
End of this report.
*Only one computer was damaged in the making of this report.  Dropped my Surface Pro.  Glass pieces everywhere...
  Don't all PETC on me.  People for the Ethical Treatment of Computers, of course.
