J-RAD
- Orem Utah
Thanks everyone for your responses! So we went out yesterday just to test things out and my buddy got up. Not the best wave by any means, but he got up and eventually went ropeless for a minute, then wiped out. I'm definitely looking forward to having a whole week on the water to figure it out and enjoy. Couple of questions...
View attachment 77000 View attachment 77001
Nice work, keep at it and you'll get it more dialed in and you/your rider will find that sweet spot.
1. Has anyone had issues with the engine on the high side(when listed) not starting? I had this happen to both sides, starboard engine when listed to port and port when listed to starboard. I haven't ever had an engine not start until yesterday when listing the boat.
I frequently experience this when surfing. It's always on the low side which is the port side for us. I believe it was @swatski in another thread that brought up the theory of the water box becoming laden with excess water from dropping lower below the waterline, therefore taking a few extra cranks to get started. Others have suggested heat soak. I'm not sure it's been definitively answered, but it's normal.
Can you define "wouldn't get up"? . . . .if you mean wouldn't get up on plane. . . .dont expect it to while surfing. Frankly, without a wedge to knock down the jet wash you want the pumps as low in the water as possible, and the nose as hogh as possible so the jets are pointing under the wave.
Agreed, you won't really get on plane while surfing. The boat will plow thru the water just under plane.
3. What were your RPMs for 9-10mph? I am only at 1075 altitude but am running similar ballast weight and am usuall around 5600RPM for 9-10mph. Someone who surfs at hight alt should chime in here.
I'm at 4500', I can't recall exactly what my RPM's are at, I've paid more attention to the speed since installing the Ridesteady. Prior to having the Wake Wedge, I seem to recall running the high side 6k+ and 5500-5800 on the surf side.
