This modification will probably work on the 190 series boats also, because I believe our hulls are exactly the same. The size access hatch I picked for my needs was the biggest found without going to a super size hatch. It's outer dimensions are, 12.875" x 16.875", inside dimensions are, 9.625" x 13.5". You might find a bigger one that will fit in that space, if you search around.
The 13x30 definately won't fit. The 13x24 looks doable if those dimensions are for the hole cut out, and you keep the door frame close to the floor. The real test will be when you have the door in your hands, and hold it up to the side wall. My uneducated guess is that it will work, but don't throw away the reciept.
Will the ski locker interfere with the larger door? I know with the 242 door, if it is open and folded back it keeps the ski locker from opening. That slight protrusion close to the floor could make a difference.
The 13x24 looks doable if those dimensions are for the hole cut out, and you keep the door frame close to the floor. The real test will be when you have the door in your hands, and hold it up to the side wall. My uneducated guess is that it will work, but don't throw away the receipt.
After reading the other comments, "Steined" brought up a valid point about the ski locker in the floor. I went out and looked at my boat again, and he is right. My new door is 2.5 to 3 inches off the floor, and the ski hatch clears it by only 1/4 inch. This means that the 13x24 hatch won't work because it will need to go close to the floor. It looks like you'll have to go the same route I did, and use the 13x17 hatch. It's not a real big opening but it allows access to a whole lot of usable storage space.
