tony mikkelsen
- Lago Maggiore, Italy
- SX
I am a relative newcomer to this forum so I hope I pose this question correctly. I have my SX210 2007 since new and the boat has been rock solid since I bought it - until yesterday when it has blew the 30 Amp fuse which is placed behind the screwcap on the ECU box. I replaced it with the spare 30 Amp fuse and it blew that as well... anyone have any good explanations to why this might be happening...?
We have been using the boat consistently and it has never before given us problems. I have changed oil, filters and sparkplugs regularly. I had to change the key assembly earlier this year, as one of the key blocks was broken, but that's literally the only 'non standard' maintenance issue I have had up to yesterday.
We took the boat out yesterday morning and everything worked great. We had a break of an hour or two where the boat was being battered a bit around by the waves but nothing serious and then when I wanted to start the engines again, the little bib that normally comes when you turn the key to the starboard engine to the middle position didn't sound and the engine didn't crank. The port engine started and was working normally.
I have been going through the A) Engine wont turn over at all tread and found the blown 30 Amp fuse - as mentioned - and it blew the spare one as well... any help to find out what could be behind this issue is very much appreciated...
