Brad_Ct
- Alva Fl
- SX
As some of you know I bought a 2006 SX230 from veedubtek last month and as he described it is rough with both engines seized.
That being said the first thing I did was to pour Marvel Mystery oil into the cylinders and covered it up expecting to not do anything to it until after winter. Well today it was almost 70 and I got out of work early and my curiosity got the best of me so I pulled enough of the cover off to get the into the engine compartment to see what I could see.
I pulled the starboard coupler shield off and found that somehow the bilge pump hose had gotten wrapped up in the intermediate shaft and was still attached to the end of the hose going out of the boat. I am guessing this happened at a low speed and killed the engine. After removing the hose I put a pipe wrench on the coupler and tried to turn the engine over to no avail. I put some more oil in the cylinders and moved over to the port engine.
I removed the coupler shield and with a pipe wrench on the coupler to my surprise with a couple whacks on the end of the wrench with my hand I was able to get it to free it up. After rotating the engine back and fourth several times I was able to get full rotation. Not sure how much damage has been done but I think at this point this engine can be saved. Put more oil in the cylinders put the plugs in and covered it back up most likely until spring.
@veedubtek You went above and beyond with everything you did to get the boat and trailer ready for the shipper, thank you!!
