Tach problem
Hi Evan,
Was this resolved? I have the same exact problem would love any additional insight.
Thanks
David
2007 sx230
Spring startup and the tachometer stopped working. Never had this problem before. Worked first, changed spark plugs, started engines again and no tach working.
Any recommendations?
2007 sx230
Are all of the other gauges working?
2007 sx230
My guess would be that you have an electrical connection issue somewhere.
I would swap the tachs from side to side. If the problem moves with the tach then you have a tach problem. If not then you have an electrical or signal issue before the tach.
