J-RAD
- Orem Utah
Since I started my watersports business this year I've had the opportunity to demo a lot of wakesurf boards behind my '16 AR240. My typical setup has been with the Gantlin Products Wake Wedge and their Custom Transom Ballast Bag. Which has been awesome! I've been able to go ropeless and play on every board in our inventory with it. I've done this with the intention of showing my fellow jetboaters how these boards will perform behind your boats. It's been a chore... ?
There's been a problem though. Not everybody wants to make such a large investment in surfing mods, but they want to try it out with a board that actually works... Hence this experiment:
Here are the details of my setup:
Results of this experiment: Successful!
Can the Slingshot go ropeless on a "stock" Yamaha setup? You bet it can! My runs were short, I know... conditions were choppy that evening and when surfing in a circle that can lead to a point where eventually those waves are not being shielded by the boat. Also, the driver has to be very consistent to maintain the wave and pocket. The fact that I had Ridesteady helped with the consistent speed, but the system did still function properly with the engine sync of and throttles offset by a few k RPMs. Had conditions been a little more ideal I'm certain I could have surfed longer and farther.
In short, the board can give most any average size rider the best chance if going ropeless. Add a few bodies to the back seat and you'll do even better.
These boards are in stock in our store:
Message me if you want the jetboaters discount. Shipping is free across the mainland US. ?
- 2016 Yamaha AR240
- Board - 2019 Slingshot Coaster 5'0" (the smaller version)
- Rider weight - 190 lbs
- Ballast - One 500lb bag under the port seat filled to bulging. No other ballast used.
- Human ballast - Basically none. Unless you count my wife driving and 35 lb 5 year old son whose hand you can see sitting on the starboard side.
- Fuel - Was at 1/3 tank
- Water depth 10-12ft
- Speed 9.8-10 MPH
- Offset engine RPM
- Ridesteady was active with engine sync off
- Gradual turn surf side
Transom Watersports | Wakeboard | Wakesurf | Vest | SUP
Best gear behind any boat for wakeboarding, wakesurfing, wakefoil, wakesurffoil and SUP. Life is better behind a boat with Transom Watersports.
www.transomwatersports.com
