Thrust Vector XL warped - any way to fix this?
shrivel
Acworth, GA
I bought a 2014 AR192 a few weeks ago and it's been sitting in storage since then. I pulled it out today to go over the mechanicals and install my new Lateral Thrusters and noticed that the Thrust Vector XLs that are install on it are warped and bowed. As far as I can tell it appears to be installed correctly and all the screws are still in it. Has anyone ever seen this before? Does JBP offer any sort of warranty on them? Does anyone know if it's possible to straighten them out - maybe something like putting them in an oven or some sort of heat to bend them back?
I'm kind of pissed, because I just placed my order for my Lateral Thrusters only and could have saved some money on the combo if I had known I needed to replace them.
captras
Lake Livingston, Texas
I have the Cobras, and do believe they can be reshaped. Not sure about the TVs, but if not, I bet Will would honor that combo special if you called him and explained.
svana
Riverview, FL
I bent mine out of shape in a similar fashion when beaching - the plastic doesn’t really have the ability to retain a warped shape, it’s more likely the cross members are bent. Try taking them off and letting the blades rest freely, they should just sit perpendicular. If so, then it’s just a matter of bending the bracket back into place should just require a little hammer work.
shrivel
Acworth, GA
I actually did that. The blades are jacked up so badly
svana
Riverview, FL
Wow, can’t say I’ve ever seen that (albeit my experience is limited). Like captras said, I’m sure Will will be able to help you out.
suke
Holly Springs, NC
I had the same issue on mine. What I did was heat them up pretty good with a heat gun, not to the point of melting of course, then took 2 2x4's and clamped the TV between em. Straight as an arrow after they cooled off. I'm getting ready to swap out my TV's for cobrajet, though. I believe I have a thread running around here where I straightened them.
shrivel
Acworth, GA
That is exactly what I needed to hear! I will do this as soon as I can.
JetBoatPilot
Event Sponsor
Event Sponsor
Panama City, Fl
Looks like the cross member was installed upsidedown. Not sure that has anything to do with the fins being warped. Normally fins being warped comes from a submerged object strike or from allowing the fins to rest on the bottom while at anchor. They can be easily bent back in place by hand and if you'd like to try that first that may be the easiest way to remedy this. I'd recommend flipping the cross member over and reinstalling it. If its twisted or bent out of shape we can warranty at no charge if you'll pay shipping. We may also have left over XV fins on hand so if they can't be reshaped to your liking we can warranty those too.
When at anchor we typically recommend that you keep the boat floating in at least knee deep water and keep an eye on the tide if you're in a tidal zone. If you need to bring the boat in shallower you can flip the fins up and place a small piece of pool float noodle into the nozzle opening and then let the fins and cross member rest on the pool float. this keeps them up and reduces the chance of striking the bottom.
shrivel
Acworth, GA
Holy crap, you're exactly right about the cross member. Installed that way would constantly be forcing the fins downward into the jet wash, instead of up and out of it. I'd imagine the constant torque on the fins would warp them over time.
Thank you for your help and I'll definitely try that!
Dixie Highway
Daphne, AL
I've seen plastic parts that are warped like that fixed by soaking in hot (almost boiling) water. Leave them in until they get nice and soft, then place them under a flat, heavy object until they cool.
shrivel
Acworth, GA
So I basically did exactly what Dixie Highway suggested and it worked perfectly. Put the fins in a pan of boiling water for about 10 minutes and then clamped them between two boards and left them until the next day. They were straight as an arrow after that. The cross member was bent slightly, but I straightened that out using a couple steel bars. Put it back on the boat and it seems like I'm back in business! Thanks to everyone that responded.
JetBoatPilot
Event Sponsor
Event Sponsor
Panama City, Fl
That's great to hear! Be safe out there!
