Thrust Vectors - Changed my mind
Foobar
Charleston, SC
@JetBoatPilot
After fishing a couple of times with the Cobras I have made the decision to put the JBP system back on. It allows me to maneuver the boat with the tide moving infinitely better than the Cobras.
Seadeals
Greenville, South Carolina
Thanks for doing so much testing. We have a great selection of products available to suit specific personal tastes. I apologize if you explain in another thread; but what exactly do you mean by maneuvering the boat with tide moving? Are you referring to the slow speed handling in currents?
JetBoatPilot
Event Sponsor
Event Sponsor
Vendor
Panama City, Fl
I'm glad to hear you've chosen our product for your needs. Your feedback will be very helpful to others in making their decision.
Thanks again for all your hard work on the comparisons! It was nice to see an impartial comparison!!!
swatski
North Caldwell, NJ
@Foobar I'm also curious!
Are you making another video?
swatski
North Caldwell, NJ
The debate will never end :)
I hope so - as long as it is about innovation!
Making performance mods work: hard.
@Foobar has been posting very detailed vidoes on his boat.
ThatJeepGuy
Brooksville Florida
Thank you @Foobar for all you hard work and documentation.
Meanwhile I'm eating popcorn waiting for the post from someone else about how "I've been doing this for 85 years and I know everything and you're just wrong and those parts don't go like that and I've been doing this for 85 years (because he'll say that again) bla bla bla"
Foobar
Charleston, SC
When fishing near jetties or other types of structures. I anchor the bow away from the jetties. I then use some sort of grappling hook or reef anchor to hold the stern facing the jetties. The tide is pushing against the side of the boat. So, when I drop the bow anchor and start backing up to set the second anchor, the boat is moved several feet per second sideways by the tide. The lateral thrusters help move the stern against the current to keep the bow and the stern (and the anchor rode) perpendicular to the jetties.
I will post a video later to explain after my head heals. I currently have a nice gash on my head from the battery compartment lid. The gas strut had come loose, so when I opened the lid and let go of it, the lid smacked me and gave me a nice 2 inch gash. Of course, while I am gushing blood and nearly losing consciousness, someone asks "are you ok?". No dummy, I am not ok.
Tailwaters
St Joseph MI
Certainly makes sense and that was one benefit I thought the TV would offer.
swatski
North Caldwell, NJ
I think he is talking about the thrusters...? LTEs, not TVs. I think.
Which would make a lot of sense.
Foobar
Charleston, SC
Yes, the lateral thrusters. I am going to do some more tests. I may mix the Cobras without the fangs and the lateral thrusters to see how it performs.
Tailwaters
St Joseph MI
I thought you were running the LT's with the fangs?
Foobar
Charleston, SC
Magnum AK
Tailwaters
St Joseph MI
So you've been running those without the LT's correct?
Foobar
Charleston, SC
Correct. I am going to try the Magnum AK with the LT's. (Probably)
WTScott
The Woodlands, TX Lake LIvingston, TX
242 Limited E-Series
At the end of the day, there is no perfect solution but these products all provide some very solid improvements in handling and usability of our boats.
In my experience with both, the Cobra's are great for enhancing the underway stability and helping off throttle steering (which approaches non-existent in a stock or TV equipped boat, at least until the TV's drop down). Foobars videos showed this very well. The first time a new owner cuts the throttle and tries to steer away from a problem is a true aha or (OS) moment. The feeling of no control is very unsettling. We learn to leave on some power or use some reverse but it is very different.
The reverse ability is improved with both products but is still not great. This is true with inboards as well and an experienced hand can master it by using forward bumps to line up the boat. Outboard / IO people have a challenge making the transition. The LTE's are a huge improvement in this area and are a game changer for me. I am very pleased with the handling of my 210 and will be changing out my 240 this summer. I will miss the enhanced lateral stability at speed but the slow speed handling is more important in my environment.
One other benefit, the ability to move the stern at the dock or with skiers / boarders in the water is nice when you are fighting a wind or drift. Using the one throttle and wheel to one side will step the boat nearly lateral with very little movement.
Slack
Matthews, NC
@Foobar, I’m curious to see if your top speed is reduced going back to the lateral thrusters. Please keep us posted.
MidnightRider
Zumbro Falls, MN
Malibu
Wake
@Foobar , like others I'm intrigued by the idea of Magnum AK with the LTs - both high speed tracking and fine tuned low speed reverse control. Would be a little worried about the force added to high speed turning without the fangs to counter act. Will be really interested if you give that a try and have any feedback on that aspect.
Cobra Jet Steering LLC
Vendor
Florida
My input on the subject, lateral thrusters can not effect the top speed of a boat judging by how they are installed.
I can't see how it would do that at all it does not appear to even be feasible going forward , the thrust vector system may have a negative effect on forward top end speed and I too am curious as to the 5 mph increase cause and effect That was obvious.
I suggested it was just the 10 hours on the engine . I believe that I have noticed a slight increase in top speed after a 10 hour break in and I have broken in numerous 1800 engines but Only 1800 models , I have no experience with the other style engines. I admit I did mention the thrust vectors possibly being the cause or at least needing to be eliminated as the cause in a message to foobar but for some reason that was never mentioned.
