- Florida
- Other
- Other
@ttzz regarding your post here.
"like others I'm intrigued by the idea of Magnum AK with the LTs - both high speed tracking and fine tuned low speed reverse control. Would be a little worried about the force added to high speed turning without the fangs to counter act." Will be really interested if you give that a try and have any feedback on that aspect.
My magnum A K steering has been in use on the ak model Yamaha boats for a couple of years now , Some stand alone, some with the early fangs and some with the mega fang system.
People are doing what you suggest with negative issues on the steering being hard to turn , if you look at the size of the bolts used by Yamaha 10 mm on the rudder and tie rod as opposed to a 6mm bolt used on a sea doo or Chaparral and other new jet boats that incorporated the 4 tec systems .
The difference in strength and durability is huge.
Using the Magnum A K system will not cause any problems and it will not rip off your pumps lol.
I would suggest you inquire with people who are using the system or those who are co mingling them.
Having said that I still think having a real conventional reverse steering that actually steers, with extra power and all the added benefits of the Mega Fangs at half the price of other reverse systems is still the best route to take for the boater who wants excellent reverse steer ability and the other benefits provide by the mega fangs.
A person that is not looking for any novelty reverse steering like side thrust.
Most people expect the reverse to steer the boat responding to the helm in a predictable effective way. So I try to accommodate either boater by making my reverse system or inviting them to mix in other reverse systems with my steering.
I also make the Mega Fangs for the Ultimate systems plus I make available an alternate side force stabilizer for the late model nozzles if someone wishes to use the other reverse system with my steering system.
I can also accommodate people with the early style nozzles if they contact me.
I deal with logic, 99 percent of the time people need to have forward steering that eliminates the voids common in a jet boat operation both with the standard jet drives and the rudder type.
I do that quite nicely and have been doing so for many years.
For the 1 percent of the time I also address the reverse deficits.
And I do that affordably, I can also add the mega fang system to the thrust vector steering with the xv fins making that system steer in reverse and also help enhance the forward steering again at a very affordable price.
