1. Welcome to Jetboaters.net!
Top end rebuild
Discussion in 'Yamaha LX210, LX2000 and LS2000' started by piper84, Mar 27, 2018.
  1. piper84
    piper84 New Member
    Ratings:
    +5 / 1
    Boat Make:
    Year:
    2000
    Boat Model:
    LS
    Boat Length:
    I pulled the cyl head off and found damage on aft piston that I could not see otherwise also elongated Cyl wall in spots. This is the cyl at 90 psi comp ck even lower when wormed up. I am replacing all three pistons and ordered a remanufactured cyl head. Was recommended by supplier to also rebuild the carbarators. Dammage to piston side was on the exhaust side most likely due to a lean running carb. So I’m going to rebuild all six carbs and replace oil lines.
    • Like Like x 1
    • Bummer Dude!!!! Bummer Dude!!!! x 1
  2. boudin
    boudin Member
    76
    Houston, TX
    Ratings:
    +64 / 0
    Boat Make:
    Year:
    Boat Model:
    Boat Length:
    Yes, dirty carbs and oil lines coming off are the #1 killer of 2-stroke Yamaha's. Carbs should be rebuilt every 2-3 years. Try to use Mikuni or WSM kits. Go back with stock high/low mixture screw settings--check greenhulk.net for stock values, but also make note of the # of turns when disassembling the carb body. If you add aftermarket flame arrestors, that will also lean out the mixture--there are formulas on greenhulk.
    You might also want to pickup an impact screwdriver for stuck screws.
    -Greg
  3. piper84
    piper84 New Member
    Ratings:
    +5 / 1
    Boat Make:
    Year:
    2000
    Boat Model:
    LS
    Boat Length:
    Has enyone ever tried to use an infored digital hand held thermometer to detect a lean our hot running cylinder?
  4. M@__
    M@__ Well-Known Member
    90
    Springfield, MO
    Ratings:
    +57 / 0
    Boat Make:
    Year:
    2002
    Boat Model:
    LX
    Boat Length:
    20
    Ohh man. This is getting deep. I’ve done it on my motorcycle. Chambers are flat black. it worked.
    Not sure where to point, or how much hotter middle cylinder is, but I’m interested in what you come up with.
  5. the MfM
    the MfM Well-Known Member
    152
    Ratings:
    +132 / 3
    Boat Make:
    Year:
    2000
    Boat Model:
    LS
    Boat Length:
    20
  6. 4x15mph
    4x15mph Jetboaters Lieutenant
    1,318
    Downingtown, PA
    Ratings:
    +628 / 7
    Boat Make:
    Year:
    2001
    Boat Model:
    LS
    Boat Length:
    I have been using an IR thermometer to check the temperature of the exhaust and the cylinders/head. I don't do it frequently enough though since when I have the storage tray in, it is a pain to take it out for a quick measurement. I started this when my exhaust was clogged and my overheat sensor was tripping and limiting the engine RPM's. I think you can do a lot of preventative checks with one of these IR's especially on a 2 stroke
  7. M@__
    90
    Springfield, MO
    Ratings:
    +57 / 0
    Boat Make:
    Year:
    2002
    Boat Model:
    LX
    Boat Length:
    20
    Would you point it at the cylinder/chamber connection?
    Spark plugs?
    I almost put something about thermo couples and a digital readout and started imagine an airplane cockpit... decided to keep that to myself, but those sensors aren’t too expensive.
    My understanding is head temps drop on both sides of a perfect mix, but EGT continues to climb as you lean.
    What are they doing on greenhulk? That’s really the best tuning source.
  8. the MfM
    152
    Ratings:
    +132 / 3
    Boat Make:
    Year:
    2000
    Boat Model:
    LS
    Boat Length:
    20
    I thought of those too. I have a bunch of them wired to a panel for my boiler.
    https://www.ebay.com/itm/Red-LED-Di...468580?hash=item488abfc3a4:g:-nAAAOSwTM5YwSHS
    eBay search “ds18b20” ... could do the arduiono thing and have a touch screen at the helm to monitor cylinder temps :)
  9. M@__
    90
    Springfield, MO
    Ratings:
    +57 / 0
    Boat Make:
    Year:
    2002
    Boat Model:
    LX
    Boat Length:
    20
    I need to slowly step away from this thread.... :)
  10. 4x15mph
    1,318
    Downingtown, PA
    Ratings:
    +628 / 7
    Boat Make:
    Year:
    2001
    Boat Model:
    LS
    Boat Length:
    I point it at the cylinder and the spark plug area. I used this mostly for the exhaust though but I will get in there and measure "normal" temps on the engine head in hopes that I can be more proactive.
    I like @M@__ idea on using sensors and they do look very inexpensive.
  11. piper84
    piper84 New Member
    Ratings:
    +5 / 1
    Boat Make:
    Year:
    2000
    Boat Model:
    LS
    Boat Length:
    Well did it got the top cyl. Block installed with eng. In the boat. I used an SBT top end rebuild kit, the trick i used is to use dryer vent hose clamps to hold the rings in place and slide the cyl. Assy. On to all three pistons at one time. Was a good sound when the rings clicked in to place. Carbs are all rebuilt will see what happens when fired up.
    • Like Like x 1
  12. M@__
    90
    Springfield, MO
    Ratings:
    +57 / 0
    Boat Make:
    Year:
    2002
    Boat Model:
    LX
    Boat Length:
    20
    Good job!
Share This Page
