swatski
- North Caldwell, NJ
I have been playing with various mods for awhile... My main goal being the best engine efficiency.  I really couldn't care less about the top speed but came to appreciate it as one of few parameters that can be followed with relative ease when setting these engines / pumps up, RPM being the most useful.  All my mods are "bolt-on", or "canned" type, considered completely reliable.
So, today I saw my best speed yet.
Running at 49.3mph (gps, bottom right corner of the display), a bit unexpected, but made me happy .  It was a nice day, air temps in the 60s, water - no idea, but it's cold, almost no wind.  And there was that great light chop on the water surface.  I was running solid 47-48mph for a while without paying too much attention to my speed until I noticed going 49+.  I stopped, turned around, and the boat did it again, also checked with another speed app, so - not a fluke for sure.  But the conditions were about as perfect as it gets for any speed run.
I'm listing all the mods involved below, as it was for that run today. This is not the exact setup that I will keep, but pretty close. Mainly because I favor a slightly different setup with a bit better hookup.
Of note, this "best speed" may not seem like a whole lot more as compared to stock boat of about 43mph. Which is, and isn't, true. I can tell you, I doubt anyone would be confused driving this boat vs my stocker setup before. The boat really wakes up with these mods.
Quick run down of the mods (top speed 49.3mph, max RPM 8150 for this run):
Ribbon delete/filter
Stage 2 V-tech ECU reflash
OEM impeller repitched to 12.5/15
Lucky 13 cone with 3 spacers (10mm)
OEM venturi nozzle bored to 89.5mm
Total cost of the above would be about $1,300-1,400 for parts, plus your labor.
As you can imagine, there are many mods (not listed), which did not work in my tests. Just to mention a couple of things here:
1. Ride plate - tested various angles +/- washers, etc. - the stock configuration is awkward but works best. I would not touch it.
2. Aftermarket impellers - I have gone full circle... My best results overall are with the OEM impeller. I like the stock pitch the best, too, which runs at about 7700-7800 RPM max. Stock pitch is 13.5/15.9.
3. Wear ring - stock or the one with a replaceable plastic insert - no difference in performance.
And there is more...
My next goal is to maximize hole shot efficiency while keeping the top end above 45mph. I'm pretty close to getting almost now cavitation at all going WOT from a full stop!
I don't know how you guys with twins do it... I would have gone mad dialing-in twin pumps .  That said, I can imagine the above modifications applied to my fave Yamaha, the 212X, would make it fly.  For now, I'm actually glad I ended up, by chance, with my 190 - I have learned a ton here!
  My main goal being the best engine efficiency.  I really couldn't care less about the top speed but came to appreciate it as one of few parameters that can be followed with relative ease when setting these engines / pumps up, RPM being the most useful.  All my mods are "bolt-on", or "canned" type, considered completely reliable.So, today I saw my best speed yet.
.  That said, I can imagine the above modifications applied to my fave Yamaha, the 212X, would make it fly.  For now, I'm actually glad I ended up, by chance, with my 190 - I have learned a ton here!--
