Wayloncle
- 78154 Schertz, TX
 Drive the good tire up on this and it lifts the bad one off the ground.  Block of wood would work also, give yourself a ramp of sorts to get high enough.
That's what I do.block of wood to drive the good tire up and onto.
yep...I always have some 4x4 blocks, shovel, tow straps, traction mat, etc. in the back of the truck - you never know where you'll end up. I use a beveled 4x6 and blocks when I need to lift the toyhauler. If I need to go higher I use the floor jack that I keep inside.I would suggest that you guys who carry jacks go and make sure you can actually lift the trailer high enough to remove a wheel. These torsion thingies can get tricky and will cause you to lift higher than you think thus causing you to carry some blocks to get your jack higher. Best method is the ramp or block of wood to drive the good tire up and onto.
These are all in my truck, except the traction mat and shovel. We have never met. But if we did, you would just say, yeah, call a tow truck, he ain't diggin' us out!yep...I always have some 4x4 blocks, shovel, tow straps, traction mat, etc. in the back of the truck
Try this for tandem axles or something like. Unfortunately I know how well they work...Drive the good tire up on this and it lifts the bad one off the ground. Block of wood would work also, give yourself a ramp of sorts to get high enough.
http://www.amazon.com/Trailer-Aid-Tandem-Tire-Changing/dp/B000I4JPZE
