Trailer with poles if going to rain?
Pinhacker71
Verona, KY
242 Limited E-Series
I am traveling tomorrow and taking boat with me. Big chance of rain. Should I put the anti pooling poles for trip under the trailering cover? I will be unloading boat and placing in wet slip as soon as I arrive. Opinions please. I usually don't place the poles while trailering because I know it puts stress on the cover.
You're correct. No poles while trailering. The cover naturally vacuums itself to the boat during trailering. The poles could cause it to rip.
The poles are to prevent pooling of water on the cover. I don't think water will pool on the cover while you are trailering.
Some folks here, myself included have shredded mooring covers while trailer-ing (thought that was a word). Mine was a result of the seam failing at the point of accommodating the tower.. I also added a slotted noodle over the windshield to ease the pressure point against the cover.
If its not torrential it blows off the bow while under way stop and go seems to help it roll off . I have been in heavy down pours and the back filled up to the point that it was a struggle to push it off and thought for sure it was going to rip but it didn't just pull over before it gets to deep and push the water off . Kind of a pain but better than dealing with everything being soaked by dirty road water. Just be careful one thunderstorm was so bad with hail and wind that when I pushed the water off the cover it started whipping in the wind with the ratchet buckle flying out of control then lighting started striking not a good place to be with the aluminum tower.
I like that!! Will be doing that mod when I get home! - thank you
I do not have a plethora of experience on trailering (word added to personal dictionary) but have done it a few times on 3hr trips as well as back and forth in my local area (1hr or less travel). The poles are always in place and on the highway I am going est 75mph. .... so far so good. No signs of premature wear nor any visual physical defects.
just my personal experience
I've trailered just over 4,000 miles this summer. I leave the straps for the anti-pooling poles in place, put the noodle over the windshield and under the strap, but remove the poles. I have found that this is a good balance between having the cover suck down into the bow from the vacuum and having the pole push up on it right at the seam. I also use folded microfiber towels to ease pressure points like the navigation lights on the bow and under the ratchet straps.
I'm not saying there is a right or wrong way, but that works for me.
Just arrived. No poles and water rolled right off cover. Always have used the noodles for windshield. Now lake time.
If your cover is new then poles are fine. If it is 2 years old then without poles and take it slow. Going fast just makes it suck down harder. The sun destroys these covers in as short as 3 years. Towing just pulls on the damaged material and kills them the rest of the way.
