Rental Property Traveling Tongue Scale
Betik
Frisco, TX
Current location: Los Angeles CA @JBehrens
Future locations 1: Raleigh, NC @jgpncll
Future locations 2: Lake O LAke, FL @tim h
Future locations 3: TBD @[B][USER=10813]orexismd[/B][/USER]
# of safer trailers out there.....11
I am keep request to rent my tongue scale, but I am having a hard time bring myself to charge you guys $30 for 3 minutes or use. That is a higher hourly rate than me and I have a graduate degree.
Anyway, long story short yall have been so helpful that I cannot put a price on it, I am will glad to send it out to whoever needs it. Just PM me your address.
If it makes you feel any better, you can check me a check for whatever makes you happy, but not required for you to be safe on the road
The scale is ready to go on a Medium Flat Rate USPS box. Please keep the original packaging.
I just moved mine back 4” which is the what everybody has done roughly. I hope that damn box anchor in the front is not going to throw my tongue weight off !!
I do appreciate the offer though but I should be close enough.
Thanks anyway @Betik
you are most welcome.
This is the best forum I've ever been on!
first page updated with current location and next in line.
Could I get in on this line? My trailer is super bumpy.
you are now on the que ( see first page).
you can send me address now or PM you when person prior to you is ready to ship.
Got it, tongue weight was spot on from the factory @450lbs. Will be on the way to Luke tomorrow.
450 is a bit heavy but better that than light.
What % should we be at?
The recommendation is 5-7% so 400lbs at the top end IMO.
Oh nevermind, I had it in my mind that it should be 6-8%, seems Shoreland'r suggests 5-7% (so a good bit less). Maybe I'll bump the winch back a couple inches tomorrow. Any wagers for how far I should slide back for the first try?
I wonder if this is covered under warranty work?
1.5 inches.
  1. I have a patio with 6x6 columns. (see picture)
  2. I move the boat just 3 to 5 inches forward of the columns
  3. I choke the wheel for forward and backwards
  4. I loosen the winch at the bow & take the safety chain off
  5. I put 2ton jack in-front of the intakes with foam padding between the boat and the jack
  6. I lift the boat until it start to be become wiggly. like barely touching the rear bunks maybe a hair off.
  7. I hung the heavy duty racket strap from the patio
  8. I pass the strap through the ubolts on the rear transom.
  9. I start tightening the racket slowly
  10. As the rackets strap is lifting the boat it is also pulling it backwards ( recall the trailer is trapped and the boat read of the boat ( ubolts) is just 5 inches forward. So gravity pulls the boat back. Kind like the pendulum.
  11. remove the jack from the rear and let the boat rest on the bunks
  12. put the jack on the front and lift the boat 3 to 4 inches
  13. loosen the post and move backwards, just enough so the ubolt is barely touching and the fiberglass is a 2 inches above the bow stopper.
  14. remove the jack from hull and the bow should rest just on top of the bowstopper an the ubolt will be in full contact with the bowstopper.
Note 1: my front bunks carry very much to the front so my boat can be supported even without the post, but you might want to use some sort of souport on the front area while the boat is no longer resting on the post/bowstopper. Do this BEFORE step 6.
Note 2: I moved my post about 20 inches and it took off about 400lbs from the tongue weight. But the new trailer has a longer wheelbase that my old trailer (shorelander)
Photo 1: give you an idea of the Patio set up. If you were to zoom in to the left on the dark side, you will see a Yellow strap hanging from the rear post.
Photo 2: this the actually patio posts that the rear of the boat was hanging from
Photo 3: rear ubolt where I passed the ratcket strap to lift/pull the boat. notice how the end edge of the boat is almost flush to the rear bunk. You should be able to see it right underneath the triptab.
Photo 4: this is where I located the jack to the rear. just infront of the intakes and the depth finder
Photo 5,6: notice had far my front/center bunks carry and support the boat ( 2x6 by 8 feet) and the rear/outer ones are 6x4 by 10 feet.
I just went quick in reverse and slammed the brakes. Put the boat back a few inches. (Keep safety chain on).... I plan doing this a few times until weight is where I want it.
I agree but warranty seems to be a hit or miss with yamaha. If you have fix it yourself, why not do it? at least you know it is done right ....
