BigAbe75
- Litchfield, IL
- X
I know hind sight is supposedly 20/20, but would the box/open lid fit under the boat, if the opening was positioned on top? But on second thought, rain water may collect around handles and leak in there.
Wondering if I shouldn’t have gone that route. I could have gotten a smaller box that opened up (designed with a lip over the edge to keep out rain) But, I didn’t want to have to worry about hitting the boat with the lid. The lid on this one is recessed a bit instead, so would probably leak if faced up. (Smaller box wouldn’t have been in the water quite as much either, to start with)
If the gap in lid seal was large enough for a paper towel to try to be sucked out when draining, it’s going to be tough for 3/8” hole or even 2 in the bottom to out pace incoming water. But it should drain in pretty short order.
Ive got some 3/4” rubber (horse trailer mat) that I used to have some weight equipment sitting on. Some totes sitting on top of a couple rubber strips may do the trick. Don’t think I can use my original carpet covered plywood anymore.
