true neutral? boat at the dock
Stang7tl
Scarab
195 Open ID
being the scarabs have the INR system do you any of you all that have them actually keep the boat running while at the dock tide up? I don't mean for a long time but for example unloading boat from trailer and moving boat to a spot then tie up and go park.
Luc Lafreniere
Scarab Forum Lead
Ottawa, Canada
Scarab
165 G
I don't have iNR on my little 165, but yes, I do this all the time. My boat has a very small amount of forward creep as most do. It does put a little bit of strain on the ropes/cleats, but it's pretty minimal. I've done it hundreds of times with no issues. Just make sure the boat is tied up properly and that you're not in a foot of water so you don't suck up debris.
Dean P
Chaparral
VRX
I have the iNR system and yes I'll dial it in to keep the boat still while I tie it to the cleats and get the trailer backed in. Then untie, put in "gear" and drive it onto the trailer. Easy-peasy...
Nexus
Baltimore, MD
Scarab
195 ID
Yep. I do use true neutral and it works great. The only thing is that you have to make sure the wheel/jet is perfectly straight otherwise it will try to spin in place. Not much of a problem with the boat tied, but I wouldn't walk away from it if it wasn't. :)
jeremie16
Scarab
195 ID
anyone have instructions on activating true neutral for a scarab 195 without a touch screen. does the boat have to be running? it's in the mode buttons I believe. anything would be helpful, new owner here. thanks!
JetBoat195G
Massachusetts
Scarab
195 G
jeremie16
Scarab
195 ID
