Jameson Clark
- Laurens, SC
- X
Obviously you should believe what makes sense to you, but I have to ask: have you ever experienced the force on your boat from that tube submarining? I find if a tube is slightly underinflated it is very easy to submarine by accident, and I've no doubt the force of that could pull my 242X right over if it was pulling from the tower at an angle from the boat.
No wakeboarder or surfer could ever produce as much drag as a submarined 3-person tube like ours (a super mable). We also have no difficulty flipping this tube 180 degrees and dumping everyone in the lake even at "kiddie speed" (30kph / 18mph), or getting enough air that you can only see the bottom of the tube from the boat, all while attached to the transom.
I have had tubes submarine on me at idle speeds plenty of times. If you have a tube submarine on you at any speed on plane, you are doing something seriously wrong.
But, even with that force, no I PERSONALLY do not believe for one minute it could capsize my boat. The pulling force that would take is extreme and would have to be a crazy angle to pull 90 degrees to the side and fast enough that the boat didn't just "mush" sideways in the water. Once again, every one do what you think is safe.
Hasn't really been a worry for me since lately everyone just wants to ride the tube right off the back of the boat and hang out and talk while going down the water!
