biffdotorg
- Pelican Rapids, MN
- Limited S
These are 100% not driven like an outboard or stern drive. Without rudder, you need thrust to turn. So even though some giggled at the suggestion to drive it like a waverunner, it is dead nuts on.
If you want this thing to out turn an outdrive, you need to save a bit of throttle at all times. And instead of lowering your throttle when turning the wheel, you increase thottle. Thrust creates turning power. A rudder is a bandaid for jets. And don't let me downplay the fins, as they are an amazing bandaid for the design of the jets, as it gives you that "rudder" effect. (I've had them on my last two boats, and bought three sets!) But this can be accomplished by using throttle. Save some for when you need it.
First rule of thumb, when it doubt, throttle out. Not the safest suggestion, but it is when practiced in open water.
Good luck
Good luck
