ultranautics jet star 1250 innfo
Jetstar 1982
Does anyone know what original impeller pitch is?
Anyone know if there are worn rings that fit from another jet. The most important thing is bolt pattern and diameter against impeller.
I can machine it if there is not too much work
Seadeals
Greenville, South Carolina
Hi and welcome to the forum. I suspect few of us are familiar with your boat/pump, so it may just take a little time for someone to chime in. What pump does it have?Feel free to share a photo or two of the boat and impeller if you have it. For now, I will give it a bump.
zipper
Boston Whaler
the MfM
That intake looks an awful lot like it’s from a suzuki wet bike.
Obviously the nozzle is different because wet bikes steered from the front ski
8A62546E-18AE-4517-A3BC-2AD1D47961F6.jpeg CDCA6029-8C21-40C3-AEAE-7E4DB47F2921.jpeg
the MfM
A couple better picsA4CB4C2B-6F39-47F3-8403-68866B39C06C.jpeg26944330-8B25-4C1B-9466-5C89DF51E8AD.jpeg
CapnDan
@Jetstar 1982
What year is your jetstar? It will either have a Susuki motor or a Merc/Force 3 Cylinder 90 HP. If it is the latter there is no wear ring. Also the pumps are predecessors to the merc Sport jet Pump. Your shaft is probably threaded which means finding a replacement impellor is hard. Bearings and seals are metric and can be found by size. If you have the susuki motor then the wetbike parts are similar till you get to the bowl
Jetstar 1982
Hi thanks for the reply.
My boat is a 1991 mod with a 50 hp 2 cylinder Suzuki engine.
Unfortunately, this engine was broken. I have now converted to a 75 hp
3 cylinders, some welding and machining to get it too fit. Bearings are new inn the I water jet. The impeller is sent off for new calibration.
I imagine an extra impeller would be nice to have.
I'm working with machining, so if I find something that almost fit, I can make it work
CapnDan
Also with the higher horse power they added this ride plate to improve bow rise and reduce porpoising.
CapnDan
How much HP do you have there ? It will be interesting to see how the HP matches your gear set up in the pump.
Jetstar 1982
It's a 75hp engine.
Impeller has been for calibration to this engine.
I haven't tried it yet but hope to try within 2 weeks.
Jet Ski
Have you had any luck finding a replacement wear ring? I have an 89 jetstar with the Suzuki 50HP, ring is shot and has no get-up anymore... hoping to find something to swap in without 100% machining. Thanks!
French Caper
Hi. Just new to this forum and bought a project Ultranautic 1250 with the 60hp Suzuki. Was wondering if you found wear ring for your jet drive and where Also needing annimmpeller
The Bud Man
Ultranautics
Jetstar
I have a 1988 jetstar 1250, I just had my wear ring rebuilt by American Jetboard, cost $150 + shipping,
butter-bean
Ultranautics
Jetstar
Here's a picture of the boat and jet . I don't know which brand it is. It is not so common with this type of boat in this country.
howdy
did you ever see a zert/grease fitting on the jet drive? the parts manual calls for one but I havnt been able to find it
thanks
tom
CapnDan
howdy
thanks
tom
If you have the three cylinder 90 hp there is a grease zert inside the steering nozzel. There is no lubrication to the impellor driveshaft at this end other than the grease. The front is lubricated with the pump oil. Not sure if you have the Suzuki set up.
butter-bean
Ultranautics
Jetstar
yes I have the Suzuki I see the 2 drain/fill holes on passenger side of jet drive the parts book calls for a zert on the drivers side
CapnDan
You might try American Jetboard at (262) 203-3005 . They own the rights the the JetStar
