NickF
- Elk Grove Village, IL
- Limited S
Very nice. Congrats. Loving the water tank back there too. You make me want to tear down my system now. I'm anxious to get started on my new build after lake season.Hey Captains...finally got around to getting the last part of my phase 4 upgrades done with adding in the 4th amp, and my rear cushions installed in my 2017 AR240.
With this addition my system is as follows:
8 JL M770s powered by 2 JL M800/8's feeding them each 200 rms.
A pair of JL M880s on the tower getting 200 rms driven by 4 channels off a JL M600/6 (2 open channels)
A pair of JL 12w3s powered by a JL M1000/1 each getting 500 rms inside of ported boxes, one under the seat behind the driver and the other in the large port storage. Getting a second vent made out of starboard to properly vent the port storage. Have already vented the other sub.
I have a pair of the JL knobs that control my towers and subs independently.
My installer has all wires hidden and loomed so it's very clean and neat. I had my rear cushions modified (twice due to speaker change) on the transom which came out nice as well.
The sound is pretty impressive to say the least...at 50% volume I can pretty much hear it well off the back when on the shore, and while underway EASILY. I didn't crank it past 75% YET....but when it was at 75% it was insane....got plenty of thumbs up and overall I couldn't be happier....it took me 4 phases to get it where I wanted but it should keep me happy for the rest of the season.
Need to figure out what to do with the extra open channels I have...prob will add then in the bow somewhere...prob some Jl M650s.
Besides the stereo system I've also had a custom wash down system added that I love, and some additional courtesy lights in the tower.
In total we have 12 speakers with 3000 watts, that is Crystal clear!
Next up is to use my wet sounds a link...cant wait!!!
View attachment 80175 View attachment 80176 View attachment 80177 View attachment 80178 View attachment 80179 View attachment 80180 View attachment 80181 View attachment 80182 View attachment 80183 View attachment 80184 View attachment 80185 View attachment 80186
Im not sure if it will matter, from my understanding and research, when speaking to JL and others the size diff wont be as audible with the power you have. I was in a similar situation and had the MX650s (off a 800/8) and wanted Mx770s but was told the diff would be marginal since they had similar internals outside of cone size...and the M770 would be a noticeable diff bc they had larger internals for higher power.I ask here. Some buddies @seanmclean and others are pushing me to change my winter order.
I currently have:
m200/2 powering a JL subwoofer.
M600/6 powering bow/rear (MX650) and tower (mx770)
Winter project:
M400/4 to power my tower (the mx770 died so M3-770 now) and M3-650's for the swim deck.
adding captains chair M3-650 area.
However, I'm getting pressure to just go ahead and resell my already bought M3-650's and put M3-770's in all these places. (if I'm going to cut holes in the boat, i might as well cut bigger ones...)
Was there really that big a difference between the 650's and the 770's?
I'm really not at the point to up my amps further.
Is this basically the same debate of current m3 vs m6. I'm planning on a pair of m3 650s and two pairs of m3 770s, all powered at 75watts each on an 800/8. Hoping I'm not disappointed. We're aiming for.sound quality, not necessarily volume. Thoughts on springing for an extra pair of 7.7's? I didn't think they'd fit in the bow areaIm not sure if it will matter, from my understanding and research, when speaking to JL and others the size diff wont be as audible with the power you have. I was in a similar situation and had the MX650s (off a 800/8) and wanted Mx770s but was told the diff would be marginal since they had similar internals outside of cone size...and the M770 would be a noticeable diff bc they had larger internals for higher power.
If the price diff isnt killer go for it, but it really depends on your listening preferences, and budget....if I was gonna go to 7.7s I wanted max output.
Going from MX650s to M770s is night and day, especially when you properly power them....I can project far and its EXTREMELY clean. Check with Odin @ earmark he can help you fig out if its worth it based on your goals.
Hope this helps
I think my problem is that the current system is crazy already. When the tower was working properly I could go to the landing to pick up friends/family and still be heard at the beach where the rest of the family were left across the lake. While cruising i can make it hurt for everyone on board (except me see below) and my dad refuses to sit on the side of the boat the subwoofer is on because the "vibrations" are uncomfortable...Im not sure if it will matter, from my understanding and research, when speaking to JL and others the size diff wont be as audible with the power you have. I was in a similar situation and had the MX650s (off a 800/8) and wanted Mx770s but was told the diff would be marginal since they had similar internals outside of cone size...and the M770 would be a noticeable diff bc they had larger internals for higher power.
Hope this helps
