JC6275
- Clifton IL.
- LS
Thank you sir. Its called exactly what it looks like ;-)JC6275st: 18580 said:@HidnNOS , the small torch is called a pen torch, should be readily available at many hardware stores, they are pretty inexpensive and handy to have..
Im anal like that, yours Isnt mine so to each there own 100%Looks nice. Much cleaner than my ghetto zip ties
Go with reviews n price, will come In handy for MANY yearsThere are a lot of them on amazon ranging from $8 to $40+. They are also called pencil torches. On one of them it even said "In accordance with federal regulations, home use of this product is prohibited." WTH?
If you have a recommendation I'll order one up. Otherwise I'll probably just pick one based on reviews and price.
Not to my knowledge. I spoke with the company owner and he mentioned that if you don't want the caps... just cut them off instead of trying to soften the glue/solvent and pull them off. I just laid mine on my miter saw and made a nice clean cut. I also installed mine under my trailer which I think I prefer.
Just wanted to add this. I got the VeVe guides for my 2013 Shorelander trailer. The bolts were an inch short. The bolts were 7" and I needed 8". I emailed the company but never heard back.
I would just pick up a galvanized bolt in the size you need at Home Depot, Lowes or any hardware store.Just wanted to add this. I got the VeVe guides for my 2013 Shorelander trailer. The bolts were an inch short. The bolts were 7" and I needed 8". I emailed the company but never heard back.
Packaged one pair per carton with all mounting hardware. Will mount to frames up to 3” wide x 4-1/4” high.
Options:
For frames up to 5-1/4" high check option T-7-8 below for longer bolts.
For frames up to 6-1/4" high check option T-8-8 below for longer bolts.
I measured my frame and it is almost 5". So, I ordered the T-7-8 which is 7". I think the standard is 6".
guess I'll find out soon enough. Will report back.
How far away from the boat sides should they be installed? Also, the PVC piping just sits loose on top on the main square tube?
