4x15mph
- Downingtown, PA
New to me 2018 AR210 with keel, cobra fangs, and OEM. I have an issue where the port throttle is shaking/vibrating/bucking periodically.
Some notes:
- This has happened at slower speeds (10 mph) and it happens at higher speeds
- the throttle doesn't shake out of the water when I rev the engine. I know it is not under load but just a note
- It doesn't happen all of the time
- This is only on the port side
I don't think this is a bucket hanging down issue since if that was the case, it would happen all of the time
I am suspicious of the aftermarket fins and it may be more of the install versus the product.
it could be the keel but the keel is connected by rods to both port and starboard while the issue only happens on the port
Any ideas to further troubleshoot? When I searched the forum, I did find that newer model AR210 had issues with the impeller cone not being tightened and it ended up in the engine being trashed..... hope not
Some notes:
