haknslash
- Lake Martin, AL
- Moomba
- Other
A member had messaged me that his AR192 throttle will slip out of the 2nd detent if using No Wake Mode and he was going to have his dealer look at it while he was getting them to winterize. I never use the second detent because it doesn't utilize TDE like the first detent is used for. But I was curious if mine would slip out as well so I decided to test that last weekend. Sure enough it does. I know you can take apart the throttle housing and tighten the tension screw but to be honest I doubt I will even do that as I simply don't use the 2nd detent so this is a non-issue for me. However I felt it's good info to show people are not alone if they have this issue with their new boats.
Without looking into this further I would suspect 2 things are at play here. 1. The bucket (slop) may need to be slightly adjusted. 2. The throttle tension screw could be adjusted inside the housing. Reason I think my bucket may need to be adjusted is because sometimes if I'm just past the 2nd detent and (very) slowly add throttle I can feel a pulsating from the lever. What I think i'm feeling is just the bottom edge of the bucket being blast with jet thrust. As you add more throttle the bucket will raise enough out of the way so that it's away from the thrust and opening of the nozzle entirely. My boat has been like that since day 1 but I always forget to look into this as it's such a rare time it happens or that I slowly add in that much throttle that it's noticeable. I'll look into adjusting my bucket in the winter.
