Welcome to Jetboaters.net!
Nothing wrong with rope surfing. I have just come to the realization that I don't want to mess with adding even more weight and gizmos, as rope surfing is fun, and very little setup. By the time we deploy all our ballast etc, then the group in the boat is ready to switch sides, or go hang out. It's so selfish, that I just rope surf and get it out of my system.
It should be considered a given that you will probably need considerable extra ballast and a wake shaping device on the boat. When you consider that actual surf boats typically weigh thousands of pounds more than a Yamaha and then carry 3K-5K+ in additional ballast, it becomes evident that adding 400 - 800 llbs to a Yamaha is probably not sufficient to produce a strong enough wave for a big rider.
For a large surfer, like the OP, the board you choose is going to be almost as important as the equipment on the boat. I'd encourage you to read threads on wakeboat forums for information about a bit more of a variety of boards than we typically see here. You are going to want something FAST and with a lot of length and volume to stay on top of the water and in the pocket. Something made of foam and epoxy like a real surfboard, not a thin pressed board. This is not likely to be an inexepensive board, but money spent here will have a big impact on how much fun you have. Foot position and technique will be very important, so plan on spending quite a bit of time holding on to the rope while trying small variations of different stances.
I agree with the statement that board choice becomes increasingly relevant and more limited when accounting for heavier riders and modest size waves.
I spend a fair amount of time reading advice on wakesurf forums and as it relates to our jet boats, you have to adjust for scale. The same size rider will need a size larger (or 2 sizes larger) board behind a jet boat than they would find preferable behind a v-drive. There are several great option that work and handle great. I don't make a recommendation on a board for jet boat owners without first asking what boat and setup they have or plan on in addition to their weight range. Both are critically important to the equation in terms of success and satisfaction. Sometimes the answer is a different board, sometimes the answer is a 5'3" vs a 5'0".
Frankly I didn't have an answer for some riders. My board choices weren't broad enough to match a board with their weight and boat configuration. The Slingshot Coaster has been a very successful in the segment because it was quite literally designed behind a Yamaha. However, despite the speed it carries, it's 5'3" size and volume would find its limit behind the most exceptional Yamaha wave at about ~285lbs. This year we have some new options with boards up to 5'6" that will be an answer for bigger riders. I don't have my own side-by-side comparison, but Yamaha has this image showing the size difference between the 5'3" Coaster and the 5'6" Boss Hoss.
I'm afraid you're also right about cost. The unfortunate truth is that the Boss Hoss will likely cost more. I typically have the margin to offer a good discount and free shipping on most wakesurfers like the Coaster. However the Boss Hoss seems to just breach the threshold on size with UPS and FedEx. They want to charge us $200+ to ship a Boss Hoss vs the average $75 to ship a Coaster. Hopefully we find a way to negotiate a lower rate... it's a bit ridiculous!
Anyway... what was I talking about? Wakesurfing is fun, no matter how you manage it. As long as it's not behind an outboard.
If we use the same principles on our 19's wouldn't make sense to put a bag in the ski locker in addition the two cubes on the transom and some extra lead on the ski side.
It depends .... are you trying to make the surfable pocket longer or stronger? I find that with beginners behind the boat, 300 lbs in the ski locker works well with 650-850 on the rear platform. The wave is a little less powerful, but the surfable length is extended by 5-10 ft depending on their weight.
Which we did when we were young, behind a 120 2 stroke, on a surf board..... in retrospect it was completely idiotic yet at the time, we thought we had everything figured out .... Scary part is, I really don't remember someone even hinting at the risk of falling into the prop.
Your boat is going to need ballast, a shaper, and a decent speed control. You'll need a larger surf-style board. You should be able to do it though. You may have issues surfing a skim, but load it down and get your wave right, no issues. Here's my results on a similar sized boat.
So i’m looking at the Yamaha 255 XD for week surfing. Do you believe it creates a large enough wave for a 200 pound 6 foot two man? I have to worry about docking depth and I like the versatility. But I can’t seem to figure out if it creates a big enough wave. What are your thoughts?
I have the smaller version of your boat - 222XD and it throws a good enough wave for myself (6' 200#) to go ropeless after the wave cleans up. I am in fresh water and have a dock / boat lift so I need a boat that can access 30" of water in late fall - Yamaha is that boat. I surf "goofy" and so do my kids. Our Starboard ballast pump failed so I added 200# of steel on the swim platform + 500# of ballast surfside + Full Swim locker ballast + 600# of people to get a wave decent enough to carve. I previously surfed on a 5'9" HyperLite LandLock surfboard but it limits your carving ability. I recently upgraded to a 2023 Slingshot Coaster 5' board because the price was right ($300) and I wanted to see if I could go ropeless on a much smaller board. I've enjoyed the new board and my 135# daughters also use it if they don't want to swap out boards. My surf photos must be on my kids' phones.
It really depends on the board and your abilities. My 23yo kids seem to have no problem behind our 212x. My daughter is 115lbs - my son is 200lbs. But they’ve been doing this a long time.
Meanwhile I see MC’s and Nautiques everywhere with someone holding onto the rope.
We also have a Landlock and agree with your description - I’m the only 1 that uses it. The kids each have their own boards.
I have a 2020 scarab 215 wake with the top of the line options including the twin 300 hp supercharged rotax ace 1630 engines , and i have no problems pulling up very large , old adult men who have definitely no aged as well as they think , but i put the ski mode on 9.5 mph and set my ramp to full blast and its as like im pulling a tube of litle girls .
I would definitely call this boat , and i buy and test drive the boats all aummer as i live on a lake , the perfect boat for all water sports and and all around cruiser , its also fot 600 hp for some g force fun . Unfortunately i will sell it this year or next and try a yamaha as i will have to find out what im missing .
