HangOutdoors
- Royal Oak, MI
Downside of the "easiest way" is that both of your batteries would be draining equally when anchored and listening to music. In theory, you could drain the starter battery too much using this method. The point of the switch is to isolate the "house" battery to power only the helm and stereo while the "starter" battery is delegated to exclusively starting the engines. This way the starter battery is never depleted past the point of being able to crank the engine. The ACR is essentially a smart device that connects the batteries only when the engines are running so both battery banks will charge when underway.
Totally agree. Could care less if my house battery dies, as long as I can crank the engine and run the bilge I can handle whatever I need to do.
