VitaminSea
- Central FL
- SX
Hey Guys & Gals - I decided to swap out the ride plate on my 2016 VX Cruiser HO, for the new 2019 VXR/GP due to its extended running area, and better tracking. My challenge is with removing the 4 screws that hold the paddle wheel (speedo) in place, They are being very stubborn. I read elsewhere they tend to strip easily, and to use an impact driver, and just use enough force to allow numerous “click, click, clicks”, and eventually they will loosen up. So I tried that and eventually one of the heads stripped. I took a pause and sprayed with PB Blaster to let it sit over night, tried again with the impact driver, still no luck. Another technique I read was to “drill them out”. I’ve never had the pleasure of drilling out a stripped screw/bolt before, so I purchased a set of extractor bits. After drilling out the screw head, and inserting the extractor bit, the bit broke!!!
The cable on the paddle wheel is not very long, so I can’t remove the ride plate and try to work on it from behind, or any other orientation other than under the ski....
Any suggestions? Please be specific, as I’m not overly familiar with some mechanical techniques.
