Nightmare
- Southern California
- Limited S
We have an upcoming trip to the CA coast. We have reserved a wet slip in the marina for a week. I would like to have the bypass valves installed, but I don't know if I can make that happen before the trip. I'm not even 100% sure if we will have fresh water on the dock. I assume as long as I flush the system real good when I get home a week won't hurt anything. I do need to order the Salt Away, dispenser bottle, and the short flush hose.
Green is my spot ( I think) and Red are the other available spots:
For some reason, they tell me that they only rent the "End Ties" at this marina. I'm not super happy with that, but I think I have the best possible spot. There is a short wall between my spot and the main channel. I have 4 dock lines (15') and 2 Spring Lines (25'). I want to make sure the boat is correctly tied up. Here is my diagram. I could throw an extra line on the Bow Eye and/or one off of the Stern Trailer D ring.
We are going to travel from Long Beach to Newport Beach. It is about 16 miles. I plan to stick pretty close to shore. But if we get brave we might try a trip over to Catalina (22 miles across the channel). I have heard that I should only go in good weather and EARLY in the morning. I'd like to hear if any other 24' and under boats have made that trip.
Shopping List Includes:
Handheld VHF Radio ( Probably the Standard Horizon HX890)
Night Time Signal Device (probably an LED Flare) - I don't plan to be out on the water after dark
