ralphsmithiii
- Tampa, FL
Hey guys, as I wrap up my first major round of aftermarket JL Audio upgrades, I found myself wondering if I should consider adding the Wet Sounds WS-420BT or original-non BT eq to my setup. So far I only have an hour or two on the boat tweaking and tuning the setup I just installed (6 MX650's, 1 10" IB Sub, M800/8 amp) and its much better than I expected over the factory unit. I do find at 0 treble/0 bass / loudness off, 60hz on the coaxials, 50 on the sub to sound pretty good so far. However, the tweeters surprisingly are bright with the 650's and there's some lack of midbass in the cabin speakers I added, I believe because these speakers need more room behind them (in the mid-cockpit) to produce it.
With that, I've tuned it so far to my likely but I've always run a eq on all my car audio setups. So, I'm wondering if the WS-420 is going to let me really dial in the treble (highs) and maybe tune in some mid-bass (unless its just not possible because of the physical install and lack of depth the speakers). Don't get me wrong, this setup so far sounds 10x better than the factory setup and the 1 10" IB sub hits much harder than I also ever expected. I was planning on adding a remote knob for the single amp and I can already see I'll be adding more than likely a pair of transom speakers by summer time. At that point, I'm thinking I'd add a second JL remote knob and use it for "zone control".
And thus, how good is this unit for really dialing in the sounds via bass, mid-bass, mid, and treble? I'm not super concerned with the PA system or even zone-control at the moment but more so tuning what's already installed more than what I can do via the amp and head unit settings.
