Tiger J
- Santa Rosa Beach, FL
- X
Thanks! It looks like I am going to try some wet sanding. (Temporary lapse in judgement: The holidays can make you do crazy things sometimes.)Why would you put that abrasive pad on the gel coat????!!! Hindsight now...sure but man that is like running razor blades over a fresh paint job on your car.
Don't worry. Those can likely be buffed back out. May even have to do some wet sanding but it will come out so long as you don't feel any grooves with your fingernail.
FYI to remove stickers use a heat gun, rubber eraser wheel, goo gone and believe it or not.....CARNUBA WAX and good ole elbow grease once you have the sticker removed. This is how we always did it back in my detailing lifetime.
